An mBot Ranger apparently uses an Arduino Mega 2560. I got it to help with my Arduino learning and dragged it out of it’s cave whilst there is a lull in the Crane progress. I would like to use it’s ultrasonic sensor to make it go forward then turn right every time it senses a blockage. I found this sketch
* @file mBot Ranger Autonomous Mode.ino
* @author IntoRobotics.com
* @version V1.1
* @date 2016/05/13
* @description this file is sample code for the mBot Ranger kit
#include "MeAuriga.h"
#include <SoftwareSerial.h>
MeUltrasonicSensor ultraSensor(PORT_7); // Ultrasonic module
int distanceLimit=50; // Maximum distance we want to ping for (in centimeters).
int maxPwm=255;
int halfPwm=200;
int turnPwm=150;
int d=500;
int frontDistance;
//Motor Left
const int pwmMotor1 = 11;
const int inMotor1_1 = 49;
const int inMotor1_2 = 48;
//Motor Right
const int pwmMotor2 = 10;
const int inMotor2_1 = 47;
const int inMotor2_2 = 46;
void setup()
Serial.begin(9600);
pinMode(pwmMotor1,OUTPUT); //We have to set PWM pin as output
pinMode(inMotor1_1,OUTPUT); //Logic pins are also set as output
pinMode(inMotor1_2,OUTPUT);
pinMode(pwmMotor2,OUTPUT); //We have to set PWM pin as output
pinMode(inMotor2_1,OUTPUT); //Logic pins are also set as output
pinMode(inMotor2_2,OUTPUT);
void loop()
GetFrontDistance(); //Get the ultrasonic distance in cm
if(frontDistance>=distanceLimit){
FullSpeedMode(); //The robot is in full speed mode
else {
ReduceSpeed(); //Reduce the speed of the robot
Stop(); //Stop the robot
do {
TurnRight();
delay(200); // Wait for sensor to stabilize
} while(frontDistance<distanceLimit);
int GetFrontDistance(){
frontDistance=ultraSensor.distanceCm();
Serial.print("Front distance (in cm) is: "); //For debugging
Serial.println(frontDistance);
return frontDistance;
void FullSpeedMode(){
digitalWrite(inMotor1_1, HIGH);
digitalWrite(inMotor1_2, LOW);
analogWrite(pwmMotor1,maxPwm);
digitalWrite(inMotor2_1, LOW);
digitalWrite(inMotor2_2, HIGH);
analogWrite(pwmMotor2,maxPwm);
Serial.println("Full speed mode"); //For debugging
void ReduceSpeed(){
analogWrite(pwmMotor1,halfPwm);//Set speed via PWM
analogWrite(pwmMotor2,halfPwm);//Set speed via PWM
Serial.println("Reduce the speed"); //For debugging
delay(d);
void Stop(){
analogWrite(pwmMotor1, 0);
analogWrite(pwmMotor2, 0);
Serial.println("Stop");
delay(d);
void TurnRight(){
analogWrite(pwmMotor1,turnPwm);//Set speed via PWM
digitalWrite(inMotor2_1, HIGH);
digitalWrite(inMotor2_2, LOW);
analogWrite(pwmMotor2,turnPwm);//Set speed via PWM
Serial.println("Turn the robot right"); //For debugging
but can’t get the bot to do more than go flat out backwards. Is there somewhere I can go that will let me paste the sketch then single the bits out and explain what they mean?
