Hey, sorry for the delay. All code files as per Pycom Libraries on Github
Nano Gateway
config.py
import machine
import ubinascii
WIFI_MAC = ubinascii.hexlify(machine.unique_id()).upper()
# Set the Gateway ID to be the first 3 bytes of MAC address + 'FFFE' + last 3 bytes of MAC address
GATEWAY_ID = WIFI_MAC[:6] + "FFFE" + WIFI_MAC[6:12]
SERVER = 'router.au.thethings.network'
PORT = 1700
NTP = "au.pool.ntp.org"
NTP_PERIOD_S = 3600
WIFI_SSID = 'XXX'
WIFI_PASS = 'YYY'
# for AU915
LORA_FREQUENCY = 916800000
LORA_GW_DR = "SF7BW125" # DR_5
LORA_NODE_DR = 5
ABP Node
from network import LoRa
import socket
import binascii
import struct
import time
import config
# initialize LoRa in LORAWAN mode.
# Please pick the region that matches where you are using the device:
# Asia = LoRa.AS923
# Australia = LoRa.AU915
# Europe = LoRa.EU868
# United States = LoRa.US915
lora = LoRa(mode=LoRa.LORAWAN, region=LoRa.AU915)
# create an ABP authentication params
dev_addr = struct.unpack(">l", binascii.unhexlify('2604126C'))[0]
nwk_swkey = binascii.unhexlify('ADFAAE719468D488F6125362B4197282')
app_swkey = binascii.unhexlify('23AA3ED54B9F8451A7CFCF416140775A')
# remove all the non-default channels
for i in range(0, 72):
lora.remove_channel(i)
# set the 3 default channels to the same frequency
lora.add_channel(0, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
lora.add_channel(1, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
lora.add_channel(2, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=5)
# join a network using ABP (Activation By Personalization)
lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey))
# create a LoRa socket
s = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
# set the LoRaWAN data rate
s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR)
# make the socket blocking
s.setblocking(False)
for i in range (200):
pkt = b'PKT #' + bytes([i])
print('Sending:', pkt)
s.send(pkt)
time.sleep(4)
rx, port = s.recvfrom(256)
if rx:
print('Received: {}, on port: {}'.format(rx, port))
time.sleep(6)
OTAA Node
""" OTAA Node example compatible with the LoPy Nano Gateway """
import socket
import binascii
import struct
import time
# Initialize LoRa in LORAWAN mode.
lora = LoRa(mode=LoRa.LORAWAN)
# create an OTA authentication params
dev_eui = binascii.unhexlify('70B3D5499B5361C5') # these settings can be found from TTN
app_eui = binascii.unhexlify('70B3D57ED000FF1C') # these settings can be found from TTN
app_key = binascii.unhexlify('A72D4289A54613C3EB4738CB25B6BF5C') # these settings can be found from TTN
# set the 3 default channels to the same frequency (must be before sending the OTAA join request)
lora.add_channel(0, frequency=916800000, dr_min=0, dr_max=5)
lora.add_channel(1, frequency=916800000, dr_min=0, dr_max=5)
lora.add_channel(2, frequency=916800000, dr_min=0, dr_max=5)
# join a network using OTAA
lora.join(activation=LoRa.OTAA, auth=(dev_eui, app_eui, app_key), timeout=0)
# wait until the module has joined the network
while not lora.has_joined():
time.sleep(2.5)
print('Not joined yet...')
# for i in range(3, 16):
# lora.remove_channel(i)
s.setsockopt(socket.SOL_LORA, socket.SO_DR, 5)
# make the socket non-blocking
time.sleep(5.0)
""" Your own code can be written below! """
s.send(b'PKT #' + bytes([i]))
time.sleep(4)
rx = s.recv(256)
if rx:
print(rx)
time.sleep(6)
EDIT: OTAA code replaced with runnable code that fails to authenticate.
