- I am going to use IR BREAK BEAM SENSOR - 3MM LEDS to detect motion.
- When an object passing between the led and sensor, it triggers 5V Small Solenoid.
- The solenoid shall trigger the mechanical action of the device I have made.
- I am don’t know how to hook up the parts recommended and purchased: (A) 5V Single Channel Relay Module 10A, (B) Pololu 5V Step-Up/Step-Down Voltage Regulator S7V7F5, (C) Resistor 10K Ohm 1/6th Watt PTH.
As such, could you please help by giving me a schematic to connect all the above parts together and perform the desire action of the device. Thank you.
