This is a placeholder topic for “Mi-Light RGBW LED Controller Box” comments.
The Mi-Light RGBW LED Controller Box is a 2.4GHz RF controllable LED accessory that enables your non-addressable LED strips to change color, dim, and select pre-loaded…
is this using an ESP based chip ??
Hey Ash,
Welcome to the forums!
That Controller Box is a 2.4Ghz RF receiver box, so it isn’t working via Wifi but rather via Radio Frequency. It is meant to be used with something like the Mi-Light 4-Zone LED Remote Controller. Unfortunately that remote has been retired so the solution would be using a capable transceiver that will work in the 2.4Ghz range.
Blayden
Thanks Blayden,
Do you sell any controllers that have an ESP chip so it is Wifi ??
Hey Ash,
We dont have any premade like the above product, but we do stock a number of ESP32 boards and have a full guide on making your own using WLED and the ESP32.
Check the guide out as it is a fairly simple process and you should be on your way to getting that project up and running!
Blayden
