MicroController Recommendation for Podcast Player
Hi Bob,
I changed this by typing int and tested it again earlier as I mentioned above and the same thing happened when I did it.
John
If it was incorrect the compiler would have thrown an error.
Hi John
Not what I meant. I said to delete the line containing that term and type it manually again using “uint16_t” as before. Replacing with “int” I think just gets you back to the “255” situation you were trying to rectify.
Anyway you seem to have a work around which works for you so all good.
Hi Jeff.
Not necessarily. Sometimes something quite invisible happens during the copy and paste procedure. It has happened to me 3 times now I think. The first time I copied a whole sketch to try a couple of things and do you think I could get it to work. I compared my version with the original just about character by character and I could not see any difference. The sketch compiled OK and I thought that would fail if there was an error. In desperation I typed the whole thing manually (it was not very big) and the damned sketch worked as expected.
I believe this has happened to others and I don’t think anyone has really got to the bottom of it yet. I have not heard anything anyway. Could maybe be an invisible non printable character in there somewhere making things look like a comment (similar to “//”) and ignored so the compiler does not see an error. I don’t know. Brain is too fuzzy these days to worry too much. As long as I can fix it.
