This is a placeholder topic for “MOSFET Module (Screw terminals)” comments.
Keep your IO protected and drive high-power outputs.
Read moreThis is a placeholder topic for “MOSFET Module (Screw terminals)” comments.
Read moreI have one of these modules that I used in a project to control a fan using just a logic circuit, fed by 12v. No arduino or pico etc..
My question is, could this be used with a Pico? Will the 3.3v be enough to drive the signal pin on this board?
Given that the pico will have a 5v source and there will be a 12v source to power the fans.
My hope is to create a project with a built in menu to create a settable temperature range for the fan to turn on and off with readings from a temperature probe. At the moment it is just controlled via a potentiometer to set the low cut-off range to shut the fan down. No PWM or specific temperature range, which is what I’m hoping to achieve.
Also, do I need to protect the signal line back to the Pico, with a resistor or diode, so it won’t have any residual power back flow and cook the Pico board?
Thanks! Dave
Hi David,
Welcome!
I’ve had mixed experiences with these modules at 3.3V - these ones work quite consistently: MOSFET Power Switch Module | Buy in Australia | CE09733 | Core Electronics
At a glance both modules have a gate resistor to protect the MCU
If you wanna make everything a bit smaller these work a treat as well: Pololu Isolated Solid State Relay/Switch, SPST, 60V, 7A | Buy in Australia | POLOLU-5420 | Core Electronics
Thanks Liam!
I’ll check both of these out, the Polulu is tiny! Maybe that one will be for my final verision.
Cheers!
