attached is the code
This code works with the Machines That Emulate Humans workbook and lesson plan
Available from the Microsoft Education Workshop at http://aka.ms/hackingSTEM
It also contians code for the Rock, Paper, Scissors (RPS) workbook
This projects uses an Arduino UNO microcontroller board. More information can
be found by visiting the Arduino website: https://www.arduino.cc/en/main/arduinoBoardUno
See https://www.arduino.cc/en/Guide/HomePage for board specific details and tutorials.
This project relies upon the construction of a sensorized glove that is used to generate
signals that simultaneously drive a set of servos and display data visualization in Microsoft Excel.
The RPS functionality captures the classic hand gestures of rock (all fingers full flexion),
paper (all fingers full extension), and scissors (thumb, ring, pinky full flexion, and index, middle full extension).
The RPS code uses the game loop design pattern so that differnet time intervals can be used simultaneously
to control output frequency. This is necessary because the serial data needs to be sent at 75 millisecond
intervals but the servo need to be updated every 15 milliseconds. This is same concept found in Blink Without Delay.
A match of RPS is started after receiving a trigger from Excel. This resets several program flow variables
and storage arrays. The match consists of rounds. Each round consists of a countdown sequence and the
detection of hand gesture. At the end of the rounds a match ending flag is switched. After a pause the
final results are displaued in Excel.
David Myka, 2017 Microsoft Education Workshop
#include <Servo.h> // Arduino servo library
// Constants that appear in the serial message.
const String mDELIMETER = ","; // cordoba add-in expects a comma delimeted string
String mInputString = ""; // string variable to hold incoming data
boolean mStringComplete = false; // variable to indicate mInputString is complete (newline found)
// Time intervals used to control delays in serial messaging, servo output, and program flow.
int mServo_Interval = 35; // Interval between servo position updates
unsigned long mServo_PreviousTime = millis(); // Timestamp to track interval
int mSerial_Interval = 75; // Intervel between serial writes
unsigned long mSerial_PreviousTime = millis(); // Timestamp to track interval
int mRound_Interval = 5000; // Interval between rounds
unsigned long mRound_PreviousTime = millis(); // Timestamp to track interval
int mMatchEnd_Interval = 3000; // Interval between end of match and final results display
unsigned long mMatchEnd_PreviousTime = millis(); // Timestamp to track interval
// countdown variables
int mCountDown = 0; // variable to hold the countdown number sequence
unsigned long mCountDownStartTime = 0; // timestamp to start countdown timer
// Hand gesture constants
const int ROCK = 1;
const int PAPER= 2;
const int SCISSORS = 3;
const int NAG = -1; //NOT A GESTURE
// Hand gesture variables
int mPlayer1RPSgesture = 0;
int mPlayer2RPSgesture = 0;
int mExcelRPSgesture = 0;
// Censoring constants used in censorTheBird() - censors WHEN:
const int MIN_BIRD = 25; // middle finger is below this
const int MAX_BIRD = 55; // AND remaining digits are above this
// Sensor min/max constants
const int mSENSOR_MIN = 0; // sets the lowest sensor reading to 0
const int mSENSOR_MAX = 100; // sets the highest sensor reading to 100
// Servo min/max constants 0-180 (Note: TowerPro SG90 servos jitter when set to extreme positions)
const int mSERVO_MIN = 4; // sets the lowest servo position
const int mSERVO_MAX = 176; // sets the highest servo position
// Flexion/Extension threshold for detecting finger position
const int flexThreshold = 25;
// Sensor number constant
const int mNUM_SENSORS = 5; // 5 fingers
// 7x2 Array to store MIN/MAX values for auto calibration
int mMinMax[mNUM_SENSORS][2] = {0};
// 7x16 Array to store last 16 values for eliminating spikes
const int NUM_SAMPLES = 16;
int smoothingIndex = 0;
int mSensorSmoothing[mNUM_SENSORS][NUM_SAMPLES] = {0};
int mSensorTotal[mNUM_SENSORS] = {0};
// program flow variables
int mMatchTrigger = 0; // Excel sends 1 immediately followed by a 0 to set mStartMatch
int mStartMatch = 0; // mMatchTrigger sets this to 1 to start a match
int mMatchEnding = 0; // When the match is ending but not yet complete
int mMatchComplete = 1; // After final display of round data the match is complete
int mRoundsPerMatch = 5; // The number of rounds per match
int mRound = 0; // The current round number
//int mRoundWinner; // handled by Excel
//int mMatchWinner = 0; // handled by Excel
// Arrays to hold each gesture in a round
int mPlayer1rounds[5];
int mPlayer2rounds[5];
// Flex sensor variables
int sensor0; int sensor1; int sensor2; int sensor3; int sensor4;
// Servo variables
Servo servo0; Servo servo1; Servo servo2; Servo servo3; Servo servo4;
void setup() {
Serial.begin(9600);
// Hand 1 servos
servo0.attach(2); servo1.attach(3); servo2.attach(4); servo3.attach(5); servo4.attach(6);
* START OF MAIN LOOP -------------------------------------------------------------
void loop()
if(mMatchTrigger==1) // Excel sends a trigger to enter into a match.
mMatchTrigger = 0; // reset so we only enter into this once per match
mMatchComplete = 0; // reset match complete flag
mRound = 0; // reset rounds count
for(int i=0; i<5; i++) // reset round gesture data
mPlayer1rounds[i] = 0;
mPlayer2rounds[i] = 0;
mStartMatch = 1; // start match
if(mStartMatch==1) // Enter into this section once every round.
if( (millis() - mRound_PreviousTime) > mRound_Interval )
mRound++; // increment round number
mCountDownStartTime = millis(); // reset countdown start time
countDown(); // enter contdown sequence
getRPSGestures(); // gather gesture data from glove
mRound_PreviousTime=millis(); // reset round interval timer
// Enter into this section at the end of the match
if(mRound == mRoundsPerMatch) // After last round reset match
mMatchEnding = 1;
mMatchTrigger = 0;
mStartMatch = 0;
mMatchEnd_PreviousTime = millis(); // Start the mMatchEnd_Interval
// After last round wait for mMatchEnd_Interval to elapse,
// then enter into this section to complete the match.
if(mMatchEnding==1 && (millis() - mMatchEnd_PreviousTime) > mMatchEnd_Interval)
mMatchEnding = 0;
mMatchComplete = 1; // Trigger sent to Excel to display final results of match
// Process sensors and drive servos - keep the hand moving and data flowing
processSensorsServos();
// Read Excel commands from serial port
processIncomingSerial();
// Process and send data to Excel via serial port
processOutgoingSerial();
* RPS GESTURE DETECTION
void getRPSGestures()
* Sensors are read and finger position is determined
* as either full extension ("e") or full flexion ("f")
* gesture is a string that is built up of 3 letters
* example of full flexion of 3 fingers: gesture = "fff"
* Note: thumb and pinkie are very unreliable so they are
* not used for gesture detection
readSensors(); // get current position of fingers
String gesture1=""; // build
gesture1 += fingerPosition(sensor1); // i-index
gesture1 += fingerPosition(sensor2); // m-middle
gesture1 += fingerPosition(sensor3); // a-ring
mPlayer1RPSgesture = getGesture(gesture1); // Read player 1 RPS gesture
mPlayer1rounds[mRound-1] = mPlayer1RPSgesture; // add it to player 2 round data array
mPlayer2rounds[mRound-1] = mExcelRPSgesture; // add it to player 2 round data array
mPlayer2RPSgesture = mExcelRPSgesture;
// translates finger position (0-100) into flexion, extension, or out of range
String fingerPosition(int sensor)
if(sensor>=0 && sensor <=flexThreshold)
{return "e";} // full extension
else if(sensor>=flexThreshold && sensor <=100)
{return "f";} // full flexion
else
{return "x";} // out of range (should never happen)
// translates flexion/extension into hand gesture
int getGesture(String gesture)
{ //index, middle, ring only
if(gesture == "fff")
{return ROCK;}
else if(gesture == "eee")
{return PAPER;}
else if(gesture == "eef")
{return SCISSORS;}
else
{return NAG;} // Not A Gesture
* COUNTDOWN SEQUENCE
void countDown()
{ // enter into this and stay here until complete
int countdownFinished = 0; // reset countown flag
while(countdownFinished==0) {
int timeSlice = millis() - mCountDownStartTime; // determine time passed
if(timeSlice >= 0 && timeSlice <= 1000) { // 1st second interval
mCountDown = 4;
if(timeSlice >= 1001 && timeSlice <= 2000 ) {
mCountDown = 3;
if(timeSlice >= 2001 && timeSlice <= 3000 ) {
mCountDown = 2;
if(timeSlice >= 3001 && timeSlice <= 4000 ) {
mCountDown = 1;
if(timeSlice >= 4001 && timeSlice <= 5250 ) {
mCountDown = 0;
if(timeSlice > 5251) {
mCountDown = -1;
countdownFinished = 1;
processSensorsServos(); // Keep the hand moving
processIncomingSerial(); // Read Excel commands from serial port
processOutgoingSerial(); // Process and send message to Excel via serial port
* SENSOR INOUT AND SERVO OUTPUT CODE--------------------------------------------------------------
void processSensorsServos()
if((millis() - mServo_PreviousTime) > mServo_Interval) // Enter into this only when interval has elapsed
mServo_PreviousTime = millis(); // Reset interval timestamp
readSensors();
driveServos();
void readSensors()
// Hand sensor reads from analog pins
sensor0 = getSensorValue(0); // p-thumb
sensor1 = getSensorValue(1); // i-index
sensor2 = getSensorValue(2); // m-middle
sensor3 = getSensorValue(3); // a-ring
sensor4 = getSensorValue(4); // c-pinky
// censor the middle finger gesture
sensor2 = censorTheBird(sensor0, sensor1, sensor2, sensor3, sensor4);
smoothingIndex++; // increment smoothing array index
if(smoothingIndex >= NUM_SAMPLES) // if we hit then end of the array...
smoothingIndex = 0; // reset smoothing array index
void driveServos()
// Hand 1 servo writes
servo0.write(mapServo(sensor0)); // p-thumb
servo1.write(mapServo(sensor1)); // i-index
servo3.write(mapServo(sensor3)); // m-middle
servo4.write(mapServo(sensor4)); // a-ring
servo2.write(mapServo(sensor2)); // c-pinky
int censorTheBird(int thumb, int index, int middle, int ring, int pinky)
if(index>MAX_BIRD && middle<MIN_BIRD && ring>MAX_BIRD)
return 100; // pull it down
} else {
return middle; // leave it be
int getSensorValue(int sensorPin)
int sensorValue = analogRead(sensorPin); // read sensor values
sensorValue = smooth(sensorValue, sensorPin); // smooth out voltage peaks
if(sensorValue < mMinMax[sensorPin][0]) {mMinMax[sensorPin][0] = sensorValue;} // set min
if(sensorValue > mMinMax[sensorPin][1]) {mMinMax[sensorPin][1] = sensorValue;} // set max
// Map the raw ADC values (5v to range 0-1023) to range 0-100
sensorValue = map(sensorValue, mMinMax[sensorPin][0], mMinMax[sensorPin][1], mSENSOR_MIN, mSENSOR_MAX);
return sensorValue;
int mapServo(int sensorValue)
{ // map sensor value to servo position
return map(sensorValue, mSENSOR_MIN, mSENSOR_MAX, mSERVO_MIN, mSERVO_MAX);
int smooth(int sensorValue, int sensorPin)
mSensorTotal[sensorPin] = sensorValue; // add to totals array
mSensorSmoothing[sensorPin][smoothingIndex] = sensorValue; // add to smoothing array
mSensorTotal[sensorPin] = mSensorTotal[sensorPin] + sensorValue; // add to total
sensorValue = mSensorTotal[sensorPin]/NUM_SAMPLES; // get moving average
return sensorValue;
* INCOMING SERIAL DATA PROCESSING CODE-------------------------------------------------------------------
void processIncomingSerial()
getSerialData();
parseSerialData();
//Gather bits from serial port to build mInputString
void getSerialData() {
while (Serial.available()) {
char inChar = (char)Serial.read(); // get new byte
mInputString += inChar; // add it to input string
if (inChar == '\n') { // if we get a newline...
mStringComplete = true; // we have a complete string of data to process
void parseSerialData()
if (mStringComplete) { // process data from mInputString to set program variables.
//process serial data - set variables using: var = getValue(mInputString, ',', index).toInt(); // see getValue function below
mRound_Interval = getValue(mInputString, ',', 4).toInt(); //Data Out worksheet cell E5
mRound_Interval = mRound_Interval * 1000;
if(mMatchComplete==1){
mMatchTrigger = getValue(mInputString, ',', 5).toInt(); //Data Out worksheet cell F5
mExcelRPSgesture = getValue(mInputString, ',', 8).toInt(); //Data Out worksheet cell I5
mInputString = ""; // reset mInputString
mStringComplete = false; // reset stringComplete flag
//Get value from mInputString using a matching algorithm
String getValue(String mDataString, char separator, int index)
{ // mDataString is mInputString, separator is a comma, index is where we want to look in the data 'array'
int matchingIndex = 0;
int strIndex[] = {0, -1};
int maxIndex = mDataString.length()-1;
for(int i=0; i<=maxIndex && matchingIndex<=index; i++){ // loop until end of array or until we find a match
if(mDataString.charAt(i)==separator || i==maxIndex){ // if we hit a comma OR we are at the end of the array
matchingIndex++; // increment matchingIndex to keep track of where we have looked
// set substring parameters (see return)
strIndex[0] = strIndex[1]+1; // increment first substring index
// ternary operator in objective c - [condition] ? [true expression] : [false expression]
strIndex[1] = (i == maxIndex) ? i+1 : i; // set second substring index
return matchingIndex>index ? mDataString.substring(strIndex[0], strIndex[1]) : ""; // if match return substring or ""
* OUTGOING SERIAL DATA PROCESSING CODE-------------------------------------------------------------------
void processOutgoingSerial()
if((millis() - mSerial_PreviousTime) > mSerial_Interval) // Enter into this only when interval has elapsed
mSerial_PreviousTime = millis(); // Reset interval timestamp
sendDataToSerial();
void sendDataToSerial()
//Program flow variables for Rock,Paper,Scissors workbook
Serial.print(0); //mWorkbookMode - not used anymore;
Serial.print(mDELIMETER);
Serial.print(mMatchTrigger); // Starts a Rock,Paper,Scissors match
Serial.print(mMatchComplete); // Flag for match completion
Serial.print(mCountDown); // Countdown in between match rounds
// Hand 1 sensor data for visualization in Machines That Emulate Humans workbook.
Serial.print(sensor0);
Serial.print(sensor1);
Serial.print(sensor2);
Serial.print(sensor3);
Serial.print(sensor4);
//Current round gesture variables for Rock,Paper,Scissors workbook
Serial.print(mRound);
Serial.print(mPlayer1RPSgesture);
Serial.print(mPlayer2RPSgesture);
//Player1 gestures rounds 1-5
Serial.print(mPlayer1rounds[0]);
Serial.print(mPlayer1rounds[1]);
Serial.print(mPlayer1rounds[2]);
Serial.print(mPlayer1rounds[3]);
Serial.print(mPlayer1rounds[4]);
//Player2 gestures rounds 1-5
Serial.print(mPlayer2rounds[0]);
Serial.print(mPlayer2rounds[1]);
Serial.print(mPlayer2rounds[2]);
Serial.print(mPlayer2rounds[3]);
Serial.print(mPlayer2rounds[4]);
Serial.println();
