Just to confuse things futher, I looked in the directory and tried all the other tests, they all get the same result except for lowlevel.py which seems to work, but only on the first 16 LEDβs
Let me know if thereβs anything I can do to help diagnose. I even tried formatting my SD card and running a fresh install of Raspbian, and doing nothing but the guide and still had the same issue so hopefully that rules out anything else Iβve done on this Pi.
The WS281x is in a directory, and the path is in the command line to execute.
Initially, I too had that error, using pip3 install of the rpi_ws281x. The command line must use just βpythonβ as the script downloaded from here is not python3 code.
