Yes, this is an adorable miniature television! The visible display measures only 2.0" diagonal, the TFT comes with a NTSC/PAL driver board. The display is very easy…
Depends on the camera. If it provides composite video as an output and you’ve got some power available for the display (6-15 V DC) then yes, the onboard NTSC/PAL driver module should be able to present the video on the display.
