How interesting, have you been able to receive any form of error message? You’ve said that the driver cannot be installed, but is there any kind of warning or notification that you’re receiving through the terminal to let you know what’s going on? Thanks.
following the Microsoft procedure i get the following error
pi@raspberrypi:~ $ sudo ACCEPT_EULA=Y apt-get install -y msodbcsql17
Reading package lists… Done
Building dependency tree
Reading state information… Done E: Unable to locate package msodbcsql17
downloading the package and trying to install it manually
sudo dpkg -i msodbcsql17_17.7.2.1-1_amd64.deb
dpkg: error processing archive msodbcsql17_17.7.2.1-1_amd64.deb (–install): package architecture (amd64) does not match system (armhf) Errors were encountered while processing:
** msodbcsql17_17.7.2.1-1_amd64.deb**
i m looking forward to additional feedback on this
thanks
Luca
I’ve found the issue, the architecture of the Pi is armhf (ARM is typical for phones, some microcontrollers such as the Pi, and similar) the msodbcsql17 library is not supported by any architecture other than AMD64. Unfortunately, the tutorial that you’ve listed doesn’t suit the Raspberry Pi, you can run it only on linux systems running on a system with the architecture AMD64.
