Hi @Vx2124,
At a glance the main differences between the two kits is how capable they are going to be when adding additional modules to boost the base functionality of the pan-tilt hat.
They both contain a similar hat to control movement of the servos through a raspberry pi but the Pimoroni one also has a built in microcontroller inside of its HAT. This would allow you to combine this with a large range of extra lights, LED’s, sensors and the like.
It looks like the DFRobot kit comes with a light sensor built into the board which would be useful for measuring lighting conditions for a camera but does not have any additional functionality in the direction of a microcontroller like the Pimoroni HAT.
If you haven’t seen it already we have a guide for using the Pimoroni Pan-Tilt Hat that may give you a better understand of what this device can do.
In general, if you are just after a Pi Hat to control the movement of a camera the DFRobot Pan-Tilt HAT will do the job. If you are after something that is a little more capable for a more complex project then its probably worthwhile looking into the Pimoroni Picade Pan-Tilt Hat.
Hope this helps!
Sam
Thanks @Samuel
I have ordered the Pimoroni
No worries @Vx2124,
I hope you have fun with it, its a cool project for sure!
