Is someone able to confirm I am wiring the components correctly or can be done better, see the diagram of how I have wired the components so far.
For the solenoid, button and micro switch I am following these instructions
- How can I determine I am using the correct resistor value for the LEDs?
- Is the 36v PSU too much for the 24v solenoid?
- Does the solenoid require a fuse? if yes in-between which components would it be best connected?
- With the vibration motor to work on trigger is it correct for the wire to go to the 24v and 5v point on the terminal block or does it require to go to 24v and GND?
- Does the vibration motor require a diode, if yes in-between which components would it be best connected?
- Does the 5 Core cable need to be shielded or can it be un-shielded
Thanks.
