This is a placeholder topic for “PCIe TO 4-Ch SATA 3.0 Expander, 6Gpbs High-speed SATA Interface, Supports CM4” comments.
PCIe TO 4-Ch SATA 3.0 Expander, 6Gpbs High-speed SATA Interface, Supports CM4…
Read moreThis is a placeholder topic for “PCIe TO 4-Ch SATA 3.0 Expander, 6Gpbs High-speed SATA Interface, Supports CM4” comments.
Read moreWould this work with the PCIe on the Raspberry Pi 5? I’m looking to set it up as a NAS with 4 3.5" HDD drives. I know I’ll need extra power, any advice you’d have on that would also be good.
Hi Colton,
That board is designed for Raspberry Pi’s Compute Module and IO Board.
This board differs quite a lot from your Model B style boards and they are quite likely not compatible.
