Hey guys, now that the firmware issues is out of the way, thanks to @Trent5487676
Has anyone used the PiicoDev BME280 / Pi Pico W to publish to a mqtt server?
Cheers again and many thanks in advance.
Phil
Phil
Hi Phil,
As it happens I did this a few days ago… (See my previous post). That said I am having problems with what I think is the .keepalive part. The Pico W generally works fine using the umqtt.simple port of mqtt but if the device doesnt post for a while, Im having no luck getting it to reconnect without a reboot. Im sure this is my crappy code and not the u porting.
Jon
Its here Phil, not a lot of mqtt detail as the original thread was around getting a Pico W to write back into a SQL dB.
https://forum.core-electronics.com.au/t/pico-w-writing-into-mysql-db/15087/4
thanks…
I’ve built an array of raspberry pi “servers”, one is a dedicated mqtt, docker server and others and hosted it at one of our DC’s.
Got things flowing through to RedNode. Works well
Hi Phil,
Here’s the code that I used alongside a Weather Station kit to get data onto my HA instance.
I’ve had it run for 3+ days without it freeze, had to make some mods and haven’t connected it for a good stress test yet.
Thanks Liam,
will check it out and let you know
Phil
Hi Liam, do you have the MQTTClient file(s) ?
Phil
Hi Phil,
Inside the repo on the first link, the dependencies are listed there🙂
Hi Liam, thanks for your code and adapting it to my requirements.
I have the basics publishing to my mqtt server.
Cheers!
(post deleted by author)
