Hi, I want to use the VL53L1x with a Esp32-S2 and micro python, I should be able to use with the esp?
Hi Rick,
Yeah it will work no worries!
You’ll have to specify the bus, sda and scl pins and freq, example code can be found on the Git: GitHub - CoreElectronics/CE-PiicoDev-VL53L1X-MicroPython-Module: Firmware repo for the Core Electronics PiicoDev Laser Distance Sensor VL53L1X
The initialisation might look like this:
from machine import Pin
distSensor = PiicoDev_VL53L1X(bus=0, sda=Pin(16), scl=Pin(17), freq=400000)
The sda and scl pins can be (mostly) whatever on the ESP32’s thanks to the bus matrix.
Hey Liam…as you know I’ve done heaps with the VL53L1X… and today, I tried using it with different SDA/SCL pins. The driver crashes in init (actually doing the initial reset)
I’ve tried multiple Picos… with a few different SDA/SCL combos. After changing pin numbers and rewiring, an I2C scan shows the device just fine (so… it is alive on the new pins) but NEVER works unless I default to pins 8,9. NOTHING else connected on the bus… bare-bones setup. Pico and VL53L1X - that’s it.
Note: Not using the Qwiic connector (sort of obviously) but to be sure… I am connecting to the solder pins on the edge of the board. My cable works just fine if I use GPIO 8,9 … on say 4,5 … I2Cscan reports the device address… but the VL53L1X driver craps out immediately.
Any ideas?
Cheers, T.
EDIT 2: Now working… the culprit may have been dodgy Dupont connections. I changed wires to a different set on SDA/SCL…not as sloppy a fit as the first set - and it works just fine. Grrrr….
