I love the PiicoDev hardware. I love to program in Arduino’s C language.
I have quickly created test code to work with the PiicoDev Ultrasonic Distance measurement. It is not efficient and I will clean up later and put on github but for anyone wanting to get the Ultrasonic Distance Measurement working on a Pico in Arduino this will hopefully help get you going:
//PiicoDev p30 Ultrasonic test code
//Authored by Nigel Hungerford-Symes (based on python code by Michael Ruppe and Adafruit SR04 examples)
#include <Wire.h>
#define SLAVE_ADDR 0x35
uint8_t distance_H = 0;
uint8_t distance_L = 0;
uint16_t distance = 0;
float mm_per_microsecond = 0.343;
float reported_distance = 0.0;
void setup() {
Wire.setSDA(8);
Wire.setSCL(9);
Wire.begin(); // join i2c bus (address optional for master)
Serial.begin(115200);
while(!Serial)delay(10);
delay(3000);
Serial.println("Pico W up"); //tested on a Pico W board, but Pico is also fine.
Serial.println("IIC testing......");
void loop() {
Wire.beginTransmission(SLAVE_ADDR); // transmit to device
Wire.write(5); // measure command: 0x05 (RAW)
Wire.endTransmission(); // stop transmitting
Wire.requestFrom(SLAVE_ADDR, 2); // request 6 bytes from slave device #8
while (Wire.available()) { // slave may send less than requested
distance_H = Wire.read(); // receive a byte as character
distance_L = Wire.read();
distance = (uint16_t)distance_H << 8;
distance = distance | distance_L;
reported_distance = distance * mm_per_microsecond;
reported_distance = reported_distance / 2; //raw is round trip, need half
Serial.print(reported_distance); // print the character
Serial.println(" mm");
delay(1000);
