Hi All,
I am trying to get the sensor working on a raspberry pi 3b using the code below. However, receiver is consistently energising the echo pin. As the echo pin is constantly high, the code is stuck at the calculation line.
Just wondering if I have missed anything?
import RPi.GPIO as GPIO
import time
try:
GPIO.setmode(GPIO.BOARD)
PIN_TRIGGER = 18
PIN_ECHO = 22
GPIO.setup(PIN_TRIGGER, GPIO.OUT)
GPIO.setup(PIN_ECHO, GPIO.IN)
GPIO.output(PIN_TRIGGER, GPIO.LOW)
print("Waiting for sensor to settle")
print(GPIO.input(PIN_ECHO))
time.sleep(2)
print ("Calculating distance")
print(GPIO.input(PIN_ECHO)) # This line should print 0 but it is printing 1.
GPIO.output(PIN_TRIGGER, GPIO.HIGH)
time.sleep(0.00001)
while GPIO.input(PIN_ECHO)==0:
pulse_start_time = time.time()
while GPIO.input(PIN_ECHO)==1:
pulse_end_time = time.time()
pulse_duration = pulse_end_time - pulse_start_time
distance = round(pulse_duration * 17150, 2)
print("Distance:",distance,"cm")
finally:
GPIO.cleanup()
Regards,
Fu
