For the festive season a random light show using the PiicoDev RGB LED Module. Developed on a Pico W it should run on any Pi.
from PiicoDev_RGB import PiicoDev_RGB
from PiicoDev_Unified import sleep_ms
import random
leds = PiicoDev_RGB() # initialise the LED module
c = [ [255, 0, 0], #red
[0, 255, 0], #green
[0, 0, 255], #blue
[255, 255, 0], #yellow
[255, 0, 255], #magenta
[0, 255, 255] ] #cyan
while True:
for l in range(3): #loop through the LEDs
leds.setPixel(l, c[random.randint(0, 5)]) #pick a random colour
leds.show()
sleep_ms(200) #experiment with the loop interval
For Australia Day here is another light show using the PiicoDev RGB LED Module. It is an improvement on the above since it randomly controls brightness as well as colour. Developed on a Pico W it should run on any Pi.
#This code makes the PiicoDev RGB LED Module display a random light show
import random
while True:
leds.setPixel(l, [random.randint(0, 255), random.randint(0, 255), random.randint(0, 255)]) #pick random RGB values 0-255
leds.show()
sleep_ms(50) #try different loop intervals
