I’m using this board to drive LED strips with PWM:
It’s meant to handle “Output current: 12 A continuous” according to the description but it’s cutting out from thermal protection within ~10 seconds at 12V / 10A / 50% duty cycle. I’ve tried adding some passive cooling but it’s only marginally increased the time before it shuts down. It also requires a power cycle before it will start up again which is really not ideal.
Any insight would be appreciated. From what I can tell it’s a simple case of the part being over-spec’d.
