Product Enquiry – CE08581 Soldering Iron Stand Material and Heat Resistance
Hi, I recently purchased your CE08581 soldering iron stand. Could you confirm what material the black cup-shaped insert at the opening of the metal spring is made from, and its maximum safe operating temperature?
My Protech 30W soldering iron has a metal mounting plate that rests directly against this insert, and I’m concerned about heat transfer.
Hey there, @Brodey335674,
I don’t have any documented material specification or maximum safe operating temperature for the units CE08581 stand,
all the information we currently have available for this unit is on the product page. These are part of our cheap and cheerful range, which often don’t come with the documentation that higher end products might have.
What I can say is that it’s designed for the Hakko RED Soldering Iron 20W and works safely with that product.
Hi Brody, Jane
The pointy or “business” end of soldering irons will be much the same irrespective of Wattage. Somewhere about 300ºC to 350ºC with lead free up to about 400ºC.
The higher Wattage usually means a physically larger tip to enable the iron to solder larger masses of material without losing too much heat or solder larger quantities of smaller material jobs between iron recover periods.
The handle end of course is not very hot so you can actually hold it.
Somewhere in between is the bit you are worried about. I think as long as you insert the iron properly all the way into the stand and don’t leave it hanging half out I think you should be OK. In other words keep the hot bit where it belongs away from the plastic bits all should be good.
The only way is to try it. But if you have enough concern go for a more reputable brand like a Hakko stand which is available I think as a stand alone unit.
Quote
“Hakko stand which is available I think as a stand alone unit.”
End Quote
Maybe not. If you can is would appear Core don.t stock it but they do stock more expensive ones.
