A while ago I made a gpslogger using the sparkfun openlog. It works fine at 5hz, but misses data at 10hz. It’s reported that changing the firmware to openlog_light, allows a bigger buffer and faster recording.
I’ve followed the tutorials, but keep getting errors. I’m wondering if you can help with this?
This is typical.
> Arduino: 1.8.10 (Windows 7), Board: “Arduino/Genuino Uno”
C:\Users\IEUser\Documents\Arduino\openlog-light\OpenLog_Light.ino: In function 'void setup()': OpenLog_Light:130:6: error: redefinition of 'void setup()' void setup(void) ^~~~~ C:\Users\IEUser\Documents\Arduino\openlog-light\openlog-light.ino:13:6: note: 'void setup()' previously defined here void setup() { ^~~~~ C:\Users\IEUser\Documents\Arduino\openlog-light\OpenLog_Light.ino: In function 'void loop()': OpenLog_Light:176:6: error: redefinition of 'void loop()' void loop(void) ^~~~ C:\Users\IEUser\Documents\Arduino\openlog-light\openlog-light.ino:18:6: note: 'void loop()' previously defined here void loop() { ^~~~ Multiple libraries were found for "EEPROM.h" Used: C:\Program Multiple libraries were found for "BlockDriver.h" Used: C:\Users\IEUser\Documents\Arduino\libraries\src Multiple libraries were found for "SPI.h" Used: C:\Program Multiple libraries were found for "SerialPort.h" Used: C:\Users\IEUser\Documents\Arduino\libraries\SerialPort exit status 1 redefinition of 'void setup()'
