Hi All, just getting my feet wet with the Pyboard v1.1.
When I connect to the Pyboard through Putty, the putty interface is unresponsive. The cursor does nothing, the keys do nothing, the return key does noting.
Im running windows 10, the drive shows up as a removable storage as usual. I have loaded some code into main.py that works as a tilt level and works properly as expected.
I installed the unsigned driver from the onboard storage as described by temporarily disabling the windows bits and this completed as expected.
I tried on two computers with the exact problem so I guess at least its repeatable.
Is anyone able to suggest a method to get the onboard repl going or another tut to get it operational through the onboard repl.
Many thanks in advance,
Mark Ando
