Hello,
I have been following tutorial:
[A Guide to Excel Spreadsheets in Python With openpyxl – Real Python ]
https://realpython.com/openpyxl-excel-spreadsheets-python/#practical-use-cases)
But when I open the Python3 IDLE and enter:
from openpyxl import load_workbook
workbook = load_workbook(filename="sample.xlsx")
workbook.sheetnames
sheet = workbook.active
sheet
sheet.title
I get this:
Python 3.9.1 (v3.9.1:1e5d33e9b9, Dec 7 2020, 12:44:01)
[Clang 12.0.0 (clang-1200.0.32.27)] on darwin
Type "help", "copyright", "credits" or "license()" for more information.
workbook.sheetnames
sheet
sheet.title
SyntaxError: multiple statements found while compiling a single statement
Can anyone help please
Jason
I have tried typing in script manually, still not working:
>>> workbook = load_workbook(filename=‘sample.xlsx’)
SyntaxError: invalid character '‘' (U+2018)
or:
>>> workbook = load_workbook(filename = sample.xlsx)
File "<pyshell#6>", line 1, in <module>
NameError: name 'sample' is not defined
The first error I just don’t understand, but the second refers to name error. I have tried different paths to the file with no success.
Still need some help please
Jason
Success,
I found the path to file by right click on the file then press and hold option button. This changes copy to copy" “as pathname, click on copy” "as pathname and you have it to paste wherever you like. I am using a MacBook Pro with Big Sur.
Working things out slowly!
Jason
When putting quotes around the filename, you need to use either the single quote ’ at the start and end, or the double quote ". The same quote opens and closes the string. You were using the opening (backward?) quote at the start of the string, and python doesn’t like that. So use ‘file’ not `file’, or “file”.
Hope this helps.
