Raspberry Pi CM5 and 2 HQ camera
I am building a multi camera system using a Raspberry Pi Compute Module 5. I am planning on connecting 2 HQ camera’s to the CM5.
The goal is recording a football game (about 1 hour) with both camera’s simultanuously. Because the field is too wide to capture with 1 camera, I will use 2. During post processing (not on the PI, I will do that in the cloud) I will stitch the footages together to het a recording of the complete football field.
What I need from the HQ camera’s is 1080p50 and I have some questions.
  1. Can the CM5 handle 2 camera’s to record 1080p50 at the same time.
  2. Does the Raspberry Pi HQ Camera lose field of view when recording at 1080p50? I’ve read that it uses 2x2 binning—does this maintain full sensor FOV or is there any cropping?
  3. I am actually going to need 3 camera’s to capture the entire football field, I will use 2 CM5’s to do so. My thinking is that if I get a single CM5 to work with 2 camera’s, adding another subsystem with 1 camera and 1 CM5 won’t be much of a problem. Maybe I am missing something here?
  4. Is there anything I am missing in the overall design of this system? Or any recommendations/improvements on the hardware? There is of course some more hardware involved like a custom carrier board, power supply etc.
If I have not provided enough information, please let me know.
Thanks in advance!
Hi @Hilmi295850
Welcome to the forum!
For what you’re looking to i’d recommend using just a Pi5 rather than the CM5 in terms of cost and performance a Pi5 16GB is cheaper than a 16GB CM5 W lite and wouldn’t require a carrier board, it will be able to natively have 2 cameras recording at once through the MIPI interfaces.
The HQ camera will maintain its full FOV at 1080P it will compromise the quality in place of cropping.
It would also be worth looking into an SSD for the Pi5, both to deal with the larger files that you will have and also so you have a higher bandwidth available.
