I’ve opened a few of them (I now have 7 including some put aside last Christmas but didn’t get around to it at the time). They look rather similar inside using Ni-MH AA rechargeable 1.2V batteries, either 600 or 800mAh. Easy to check battery voltages:
- In three, the batteries were fully charged (so battery and solar panel must be good).
- One, the battery connector was corroded
- In a couple, the battery was about half charge, suggesting that the solar panel or charging circuitry probably the issue.
I assume that placing multi-meter probes across the wires coming from the solar panels when they are in direct sunlight should indicate what voltage they are generating. I might need a 3rd hand … and a bigger desk … in the sunshine …
One that I did test seems to be working OK.
I guess where the LED string wires go into the control box is the most likely point for broken wires, though there is no visual sign of damage. In some cases placing multi-meter across the wires going to the LED strings gives wildly changing voltage readings - which makes sense … the one circuit board will be driving the patterns on the lights as well as controlling the battery.
On one set, the problem seems to be the power switch itself. LEDs flash momentarily while the switch is being turned on or off, and continually if I hold it partway down - but when the power switch is turned ON the lights blink normally for about 5 minutes before stopping. Turning power switch off and on without moving any wiring starts the LEDs flashing again.
For broken wire I guess just cut off the first 10cm or so off the LED string, and solder the shortened wires back ? On one set I did cut the wires to the LED string - but that first 20cm to the controller has excellent continuity … suggesting that wasn’t where the the wire broken, and the problem is down in the body of the LED string itself ?
As I’m sure you’ve realised I am not into electronics so my goal is not to take the effort to find and fix faults - instead wondering if it is worth scavanging batteries and solar panels to use in other projects - and the answer seems to be … in many cases yes.
I expect there will be projects which require smallish amounts of solar power … such as my greenhouse … have 3 or 4 separate solar cells for different modules rather than one bigger battery to power everything.
However…
The single AA Mi-MH batteries are old tech and I may even have an AA battery charger from the old days. However charging them from a solar panel seems to be a different matter, especially in-situ.
I’ve looked on Core’s website, and see lots of cheap rechargeable Ni-MH battery packs but the only Ni-MH charger I could find is SkyRC iMax B6 V2 Battery Charger. Not only is it $57.20, but it requires that the batteries be removed from the device in order to charge.
In contrast, Core’s catalogue is filled with Li-PO chargers from only $4.80; some of which charge from solar panels.
Given that Li-PO is 3.7V and a pack of 3xAA Ni-MH is 3.6V, can one of DC-DC Charge Discharge Integrated Module (5V/2A) at $4.80, or Solar Lipo Charger (3.7V) at $8.05 be used with a 3.6v Ni-MH battery ??
If these christmas lights can do solar charging plus the twinkly lights and sell cheaply; the charging circuitry can’t be too complicated. Or is that it ? Is the recharge circuit actually so simple that no-one bothers to make a breakout board for it ?
