Im almost too embarrassed to ask because it seems such a simple task. However I need to make sure I get this right.
I have a ‘off the shelf’ string of xmas LEDs (series lights) with a single cell battery (1.2 Volt) and a small solar panel… Thats the easy bit…
I want to change the single cell battery (1.2) to a 12 volt rechargeable battery with a bigger solar panel which is now mounted on the roof.
In other words the voltage has to be dropped to 1.2 volts and a maximum current draw of 1 amp. (the specs on the LED string says Bulb Rating 3V .015 watt)
I purchased a “ADJUSTABLE SWITCHING POWER SUPPLY MODULE IN 4V-35V OUT 1.5V-30V LM2596S” which I can use to bring the voltage down but not the current.
I have to reduce the current from a maximum output of the Power Supply of 3 amp down to 1 amp…
What is the best way I can do that?
