RS485 Temperature & Humidity Sensor (SEN0438)
This is a placeholder topic for “RS485 Temperature & Humidity Sensor” comments.
This is a high-precision industrial-grade RS485 temperature and humidity sensor. It uses high-quality digital integrated transducer and reliable digital processing…
How does this device report temperatures < 0 degrees C? The temperature register is just two bytes. The examples given in the manual do not show any readings less than 0 degrees. Is there a sign bit there too that is not mentioned in the maual?
Hi John,
Great question and a very deep rabbit hole to get into.
I am not entirely sure but there is a good chance the hex in the instruction manual is in 2’s compliment which can be negative. The example that is given works with this theory.
If Jack is correct and its 2’s complement representation here is an 8 bit example:
+127 0111 1111
+126 0111 1110
+2 0000 0010
+1 0000 0001
+0 0000 0000
-1 1000 0001
-2 1000 0010
-126 1111 1110
-127 1111 1111
-128 1000 0000
Except this device is using 16 bits according to the manual.
Spot on Stephen.
Here’s a converter I have found that will help others
Thanks for the info Jack and Stephen
