Hi
I have one of the PiRTC’s but also an OLED which needs to use the I2C pins. Can the PiRTC been connected anywhere else on the PI’s or must it use the I2C pins?
Hi Romeo,
I2C is a bus, so you can connect all your I2C devices to the same pins at the same time. You may be able to create virtual i2C pins using other pins on the GPIO, but I’m not sure how you would accomplish this.
