New gauge works fine
I now realize that none of the breakout boards, load or temperature support IC2 so each take up GIO pins of which the feather has 9. This is on short of the 10 needed for two 3 pin temperature probes and two 2 pin load cell. The pH breakout has serial read.
Having solved a bit I can now track errors.
The Temperature has a problem compiling as it can not find the delay.h library and there is quite a bit of discussion of this as a common problem. Unfortunately I can find the .cpp code and am generally at a dead end in this area.
The error spat out in verbose is:
Arduino: 1.8.8 (Windows 10), Board: “Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, Disabled, 4M (no SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 115200”
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\peter\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\peter\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\peter\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:xtal=80,vt=flash,exception=disabled,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10808 -build-path C:\Users\peter\AppData\Local\Temp\arduino_build_870884 -warnings=none -build-cache C:\Users\peter\AppData\Local\Temp\arduino_cache_968787 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose C:\Users\peter\AppData\Local\Temp\arduino_modified_sketch_608652\lcdthermocouple.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\peter\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\peter\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\peter\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:xtal=80,vt=flash,exception=disabled,eesz=4M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=115200 -ide-version=10808 -build-path C:\Users\peter\AppData\Local\Temp\arduino_build_870884 -warnings=none -build-cache C:\Users\peter\AppData\Local\Temp\arduino_cache_968787 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.mkspiffs-2.5.0-3-20ed2b9.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.esptool-2.5.0-3-20ed2b9.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\esptool\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -prefs=runtime.tools.xtensa-lx106-elf-gcc-2.5.0-3-20ed2b9.path=C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9 -verbose C:\Users\peter\AppData\Local\Temp\arduino_modified_sketch_608652\lcdthermocouple.ino
Using board ‘huzzah’ from platform in folder: C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0
Using core ‘esp8266’ from platform in folder: C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0
Detecting libraries used…
“C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/lwip2/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\peter\AppData\Local\Temp\arduino_build_870884/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_ESP12"” -DFLASHMODE_QIO -DESP8266 “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\variants\adafruit” “C:\Users\peter\AppData\Local\Temp\arduino_build_870884\sketch\lcdthermocouple.ino.cpp” -o nul
“C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/lwip2/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\peter\AppData\Local\Temp\arduino_build_870884/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_ESP12"” -DFLASHMODE_QIO -DESP8266 “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\variants\adafruit” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI” “C:\Users\peter\AppData\Local\Temp\arduino_build_870884\sketch\lcdthermocouple.ino.cpp” -o nul
“C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/lwip2/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\peter\AppData\Local\Temp\arduino_build_870884/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_ESP12"” -DFLASHMODE_QIO -DESP8266 “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\variants\adafruit” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Wire” “C:\Users\peter\AppData\Local\Temp\arduino_build_870884\sketch\lcdthermocouple.ino.cpp” -o nul
“C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/lwip2/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\peter\AppData\Local\Temp\arduino_build_870884/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_ESP12"” -DFLASHMODE_QIO -DESP8266 “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\variants\adafruit” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Wire” “-IC:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library” “C:\Users\peter\AppData\Local\Temp\arduino_build_870884\sketch\lcdthermocouple.ino.cpp” -o nul
“C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/lwip2/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\peter\AppData\Local\Temp\arduino_build_870884/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_ESP12"” -DFLASHMODE_QIO -DESP8266 “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\variants\adafruit” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Wire” “-IC:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\peter\AppData\Local\Temp\arduino_build_870884\sketch\lcdthermocouple.ino.cpp” -o nul
“C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/lwip2/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\peter\AppData\Local\Temp\arduino_build_870884/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_ESP12"” -DFLASHMODE_QIO -DESP8266 “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\variants\adafruit” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Wire” “-IC:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI\SPI.cpp” -o nul
“C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/lwip2/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\peter\AppData\Local\Temp\arduino_build_870884/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_ESP12"” -DFLASHMODE_QIO -DESP8266 “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\variants\adafruit” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Wire” “-IC:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Wire\Wire.cpp” -o nul
“C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\2.5.0-3-20ed2b9/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/lwip2/include” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\peter\AppData\Local\Temp\arduino_build_870884/core” -c -w -Os -g -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -fno-exceptions -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10808 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 "-DARDUINO_BOARD=“ESP8266_ESP12"” -DFLASHMODE_QIO -DESP8266 “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\cores\esp8266” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\variants\adafruit” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI” “-IC:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Wire” “-IC:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library” “-IC:\Program Files (x86)\Arduino\libraries\LiquidCrystal\src” “C:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library\Adafruit_MAX31855.cpp” -o nul
C:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library\Adafruit_MAX31855.cpp:24:24: fatal error: util/delay.h: No such file or directory
#include <util/delay.h>
compilation terminated.
Multiple libraries were found for “Adafruit_MAX31855.h”
Used: C:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library
Not used: C:\Users\peter\Documents\Arduino\libraries\Adafruit-MAX31855-library-master
Using library SPI at version 1.0 in folder: C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\SPI
Using library Wire at version 1.0 in folder: C:\Users\peter\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.5.0\libraries\Wire
Using library Adafruit_MAX31855_library at version 1.0.1 in folder: C:\Users\peter\Documents\Arduino\libraries\Adafruit_MAX31855_library
Using library LiquidCrystal at version 1.0.7 in folder: C:\Program Files (x86)\Arduino\libraries\LiquidCrystal
exit status 1
Error compiling for board Adafruit Feather HUZZAH ESP8266.
