Hi again guys.
I have another interesting one for you.
In my line on work (Heavy Diesel and Hydraulics) I have discovered that if installing craning valves (Hose burst protection valves) on excavators or backhoes then as apart of the AS and ISO standard (ISO 8643) a hose burst test simulation must be run. There are specifications for how far the boom/ arm can drop over a certain time frame eg =<100mm in 10s. This also needs to be recorded and saved. So I am wondering if any of your ultrasonic or laser distance sensors would be suitable for this application? As well as the distance measurement the simulation must be recorded a video input will also be required. I also will require someone to write a program for me to be able to generate a distance over time graph from the sensor input as well as have the video feed beside the graph while the simulation is taking place for evidence that can be saved of a successful simulation. I can easily handle the hydraulic side of this to simulate a burst hose but when it comes to the data capturing side of it I have no idea. I believe that others use a large measurement scale and stop watches but I believe that utilising a program and sensors will be way more accurate and better evidence to have saved on file that can also be provided to my customers for their record keeping. For interest sake I have attached the performance requirement table from the standard. I need to confirm about the equalizing lines but I may have to include a turbine flow meter to be able to measure the flow rate. I am more then will to pay for help in designing this system.
Gary
Hi Gary,
While Core stocks a range of sensors that can sense distance, not too many are rated for industrial use.
It might be best to contact a consultancy that has an understanding about the relevant standards.
Hi Liam will do mate. Thanks
