Setting up the SX1262 with Pico 2 W
I am setting up a SX1262 LoRa Node Module for Raspberry Pi Pico, LoRaWAN on a Pico 2 W, with the DEV board, I need help or direction to a video on how to set it up and use it for a text chat between two of them. Does this need to be connected to the PI 4 or 5 to set it up and use it?
Hi @DrScott297390,
It might help a little more if we have some more information, could you please tell us:
  • The Dev Board Model?
  • Any additional software or code that you’re using for this project?
  • A Network Diagram of how you intend to set it up?
Here’s a great video that demonstrates how to set up a LoRa communication system using Raspberry Pi Pico boards—perfect for building a simple text chat or “ping-pong” messaging demo between two units: https://youtu.be/XV_J2V2Bvx4
I think you may be missing a little understanding of some of the lora “names/terms”
LoRa is a radio tx/rx protocol. LoraWAN is a management layer that is on top of lora to manage/abstract some parts for a specific purpose.
If you just want a point to point (no 3rd party involved) then basic lora is enough. you can either do this yourself for a point to point or use something like meshtastic that allosws you to use lora for a wider chat system and allows relaying messages.
LoraWAN is a node to server protocoal. i.e. all end nodes send data to a gateway, that gateway then sends to a server (over a network, e.g. internet), that sever then processed the data and passes the message on to its destination.
So for to nodes to chat to each other with lora wan, it will need (at a min)
loraWAN Node → Gateway → Server … some processing … → Gateway → loraWAN Node
if you just need point to point and the two nodes are within range of each other, then you could just use lora
loraNode → loraNode
Thank you for the information, I am going to try this.
Kindest regards
Dr Scott
Good morning Jane
I am using the:
Raspberry Pi Pico 2WH (Wireless WiFi, with Headers)
PiicoDev LiPo Expansion Board for Raspberry Pi Pico
They are stacked together.
Kindest regards
Dr Scott
Hi @DrScott297390 ,
This sounds like a fun project! We have attempted this sort of thing in the past using meshtastic, but I am finding conflicting information on the compatibility with the Pico 2W.
Your Pico 2W has an RP2350 chip inside it, while the older, confirmed supported Pico uses the RP2040.
I would follow this Getting Started Guide for Meshtastic on your Pico and see if you can get anywhere with it.
Hope this helps!
