Setup vpn from kodi
Hello, firstly I’m very much a novice. I have a rpi3 and use kodi only. Recently we have not been able to stream movies which from what I can gather could be out isp blocking. I’m keen to setup a vpn on the rpi. I’ve searched high and low for instructions but everything is via a terminal and I’ve also tried to find how to access a terminal via kodi without luck.
Requesting some assistance please to setup a vpn and also access a terminal via kodi if that is required.
Thanks heaps in advance
Hi Marshal,
Welcome!
I came across this tutorial here that seems to cover the subject quite well: Installing / setting up a VPN on Libreelec / Kodi for the Raspberry Pi - YouTube
Note: I havent setup a VPN via Kodi myself so am very much in the dark when it comes to the intricacies.
Let us know how you go!
Liam.
