Sms-to-shell systemd implementation
I have the the sms-to-shell [GitHub - itiligent/SMS-to-Shell: Secure remote control & interactive linux shell access over SMS. (Supports TOTP auth for remote shell commands)] working running via Crontab.
I am trying now to implement as systemd as recommended by David the program author. (If you are out there David, I joined Github but couldn’t figure out how to reach out for help there, so I am back here)
I am hoping someone can provide a bit of clarity by confirming my interpretation of what is happening in
sms-to-shell-setup.sh and sms-to-shell.service
Also any guidance - directly or via useful reference - on how to work in the root space. I have tried sudo , sudo su and su and find it a very unfriendly workspace. Im the Boss of the computer and it really doesn’t feel that way.
I think systemd has some big benefits and I would like to get it going.
I do understand that the sms-to-shell-setup.sh is a neat way to put everything in place.
So does the systemd .service file actually will look like this once the variables are applied?
[Service]
ExecStart=/usr/bin/python3
/opt/sms-to-shell/sms-to-shell.py
(Paul: This is were the py script is put?)
WorkingDirectory=$INSTALL_DIR
(Paul:# Is this /opt/sms-to-shell/
the outer directory of where the py script is??
Restart=always
RestartSec=5
User=‘root’
Additionally -
Does the actual systemd .service file go here like this?
/lib/systemd/system/sms-to-shell.service
Some questions i have:
a) How do I change the py script if I need to, with permissions being really stubborn in that folder ( /opt/ ) Definitely can’t do anything via graphical interface. Do I make a new version of script and ‘sudo cp’ overwrite it??
OR
Can I put the py script in one of my user folders where I can easily work with it or is root space better?
b) Should I change
SHELL_USER=“root” # Commands will run in this user context.
to
SHELL_USER=“Paul”
Any guidance is much appreciated.
Paul
To edit the script in /opt/, you need root privileges. You can use sudo with your editor, e.g.:
sudo nano /opt/sms-to-shell/sms-to-shell.py
You could create a new user with elevated privages. Thats what a pureist would do.
But if this isnt paid work for a contract or software for safety or secruity i think its reasonable to allow root to handle sms to shell protocol. Particuarly if the only person sending sms is you.
Oh I think you might be looking for nano. Its a text editor in linux. Have a look at a few images of nano online and let me know if ive found the right thing for you.
Hi lia,
Thanks. I am giving it a go sudo-ing my way around. using Sudo cp to put files in. Sudo rm to remove files. And Sudo nano to edit. thanks for your input. Best regards Paul
Hi Pixmusix
Thanks for your suggestions. making some small progress at the moment.
Appreciate your help
regards
Paul
