This is a placeholder topic for “Solar Panel (3.6V OC)” comments.
Power up your low voltage development board directly with this solar panel.
Read moreThis is a placeholder topic for “Solar Panel (3.6V OC)” comments.
Read moreWhat are the dimensions of the Ce09643 solar panel - thanks
Hi Jim,
Welcome to the forums! These panels are 70x70x2mm.
Thanks Jack - I am looking for a 50 X 50 panel that will put out 3.7V - obviously that would be at lower current - do you have access to anything that would fit the bill?
Meant to say 3.6V ![]()
Hey @Jim283894,
That’s getting pretty small for a solar panel!
I found this 52 x 52 x 2.6mm solar panel which is as close as I could track down.
It is a 6V panel although this wouldn’t be too difficult to step down to 3.6V.
What are you planning on using this for?
Hi Jim
Have you looked at some of the small garden and path solar lights. I haven’t measured any but they are pretty small.
Thanks Bob - the garden lights generally use lower voltage cells with AA batteries - my dad has a solar bottle light that uses a 3.7v battery - the cell has deteriorated with the weather so I thought I would look for a new one to put on
Thanks Samuel - I will have a think about that one - cheers
No Worries @Jim283894, good luck with this project!
