This is a placeholder topic for “SparkFun Pro RF - LoRa, 915MHz (SAMD21)” comments.
The SparkFun Pro RF is a LoRa®-enabled wireless board that marries a SAMD21 and a long-range RFM95W to make a compact and easy-to-use IoT Arduino board. With its … read more
What antenna should be purchased with this board?
Hi Jared,
915MHz antennas work best with this board. This board has a uFL connector for it’s antenna so you’ll need a uFL to SMA/RP-SMA cable if your antenna is SMA.
Here’s a kit with everything in one place. It’s for a Pycom board but it should work fine with this one.
Keen to see what people do with this
