This is a placeholder topic for “SparkFun RTK Reference Station” comments.
The SparkFun RTK Reference Station is the perfect solution for your high-precision geolocation, surveying, and time reference needs…
Read moreThis is a placeholder topic for “SparkFun RTK Reference Station” comments.
Read moreHi can the SparkFun RTK Reference Station transmit
NTRIP via WiFi after a survey in or fix?
Hi @Jon104979!
I’ve had a look through the docs for this product and the most relevant information about the use-cases for WiFi are here in the SparkFun Hookup Guide. That link should take you directly to the section where the guide describes the some cases:
Rover Mode: NTRIP Client with location display on (e.g.) SW Maps
- Tested using SW Maps on Android
- SW Maps connected to rtk2go.com NTRIP Server / Caster via WiFi and providing corrections to the Reference Station via Bluetooth
along with a few other mentions of wifi use case.
It seems to me from this that this implies the device won’t re-broadcast NTRIP via wifi, but i’ve never personally used these devices and may be misinterpreting that guide. You’re definitely the subject matter expert here! Have a look and let us know your thoughts.
