I’ve owned a Australian UrbanMover UM70 electric skateboard for about 10 years. I have broken the hall effect sensor in the potentiometer in the throttle handle and I’m hoping you might be able to help me by identifying the specs for the Australian part “AN 503” hall effect sensor (picture attached). If I can get the specs, I should probably be able to find a local supplier for the part. Any help would be appreciated.
Hey Charlie,
I’ve found a datasheet that may be appropriate for this sensor. It’s probably worth testing the sensor and finding out whether it provides the same readings as this datasheet for the model AN-5031 Hall Effect Sensor if so you should be able to find an applicable replacement from there. From what I can find we do stock similar hall effect sensors.
Have a great day and a Happy New Year!
Bryce
Core Electronics | Support
Bryce-
Got the link. Thank you very much, I’ll follow up on your
suggestions. Happy New Year!
-Charlie
Bryce-
Hello again. Based on the data sheet images, the AN-5031 may not be
the part I was seeking. I tried to attach a photo on the part in my
original request, but I may not have been successful. To follow up,
I am attaching the photo to this email (please see attached) and
hopefully, it will help to identify the hall effect sensor I’m
looking for.
Thank you again for your help.
-Charlie
old topic however i found this…
Based off this google search, may be similar: https://www.jaycar.com.au/ugn3503ua-hall-effect-sensor/p/ZD1902
