This NEMA 14-size hybrid bipolar stepping motor has a 1.8° step angle (200 steps/revolution). Each phase draws 500 mA at 10 V, allowing for a holding torque of 1 kg-cm (14 oz-in).
Hello,
I was looking at the datasheet of the “Stepper Motor: Bipolar, 200 Steps/Rev, 35×28mm, 10V, 0.5 A/Phase”. (Model: SY35ST28-0504a) I was interested in the Torque vs Pulse characteristic, but noticed the Voltage of the measurement was set to 24VDC. Is there a Torque vs Pulse characteristic for 10VDC for the same motor I can gain access to?
Thanks.
Unfortunately we only have the datasheet listed on the product page from our supplier.
Just a heads up, if your motor driver has current limiting you’ll be able to run higher voltages, such as those seen in the tests (just make sure the current limit is set appropriately!)
