Does anyone have experience with the dfrobot TCS3200 color sensor?
I cannot seem to get the LEDs to light up
Hi @Peter47774,
The schematic for that part looks like this
So you’ll need:
- 5V connected to VCC
- GND connected to GND
- 5V connected to LED
You could use a digital IO for LED instead, but you can test with a 5V signal to isolate code from the situation.
Let me know how you get on with it!
Thanks Graham. I worked out by trial and error that the LED needed input voltage so I am using the Arduino 3.3 V to supply this
The documentation did not show that the LED needed to be connected
[The TCS3200 Color Sensor]
Neat, I’m glad it all worked out!
By all means, drop back and share what you’ve made
