Temp & C02 Logging
hi there,
I own a company that supplies driver cooling systems to race cars. I am needing to make up a module that will read temp x 2 and also Carbon monoxide levels from the unit and transmit back through the onboard data logger.
The onboard data module reads throngs a 2 wire canbus side,
I would ideally be looking for someone to make these for me and supply them to me for a regular supply mounted in a small box approx under 4”x4” in size smaller the better.
Let me know your thoughts and we can talk further on the phone. I am Sydney based
Hi @Brendan295496
Welcome to the forum :slight_smile:
Just with your project, were you after Carbon Dioxide (CO2) or Carbon Monoxide (CO), I only ask because you mention CO2 in your post title, but Carbon Monoxide in the actual post itself.
Let’s assume CO (Carbon Monoxide), possible Nitrous etc from exhaust fumes?
  1. How do you connect to the CAN Bus?
  2. How is the temperature supplied or do sensors need to be built in/supplied?
  3. When do you need the product by?
I’m busy with a (little more advanced) CAN based multi sensor product for a US company at the moment so may be able to help… just depends on timing.
