So Im having fun with my Raspberry PI… Trying to build a monitor of a water tank level at a country property - I think I am almost there…
So first time I am using ultrasonic sensors - and umm consistency is not really there… Little disappointed I guess. Its not that I need accuracy - but I would like some consistency…
My Code is as follows - and I am doing multiple readings and averaging them out… But even doing that - each time I run the complete code, the average can change by more than a cm…
Is there anything else I can do, to try and get more accurate / consistent reading ?
I am using the Weatherproof Ultrasonic Sensor with Separate Probe - maybe that was my mistake… I really should not need a waterproof item - if I mount it securely at the top of the tank inside - water should not splash on it…
Advice ?
Code as follows
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
TRIG = 23
ECHO = 24
howmany = 20
soundspeed = 17150
total = 0
print (“Distance Measurement In Progress”)
GPIO.setup(TRIG,GPIO.OUT)
GPIO.setup(ECHO,GPIO.IN)
GPIO.output(TRIG, False)
for n in range(1,howmany+1):
print ("Waiting For Sensor To Settle - Reading ",n)
time.sleep(2)
GPIO.output(TRIG, True)
time.sleep(0.00001)
while GPIO.input(ECHO)==0:
pulse_start = time.time()
while GPIO.input(ECHO)==1:
pulse_end = time.time()
pulse_duration = pulse_end - pulse_start
distance = pulse_duration * soundspeed
total = total + distance
distance = round(distance, 2)
print ("Distance 1:",distance,"cm")
average = total / howmany
average = round(average, 2)
print ("Average Distance: ",average,“cm”)
GPIO.cleanup()
I have tried different measurements - but really confused over the variance returned by the sensor…
Eg. placed sensor pointing at a wall - at 112.5 cm away and I got results of;
Distance 1 : 112.0 cm
Distance 2 : 112.55 cm
Distance 3 : 216.85 cm
Distance 4 : 112.39 cm
Distance 5 : 112.02 cm
Distance 6 : 49.56 cm
Distance 7 : 112.6 cm
Distance 8 : 112.16 cm
Distance 9 : 112.62 cm
Distance 10 : 112.39 cm
While I expect some variance - I was not expecting to see scan 3 at double the distance, and scan 6 at half the distance…
Its not a critical app - but I am going to be un trustworthy in determining if I captured any rain this week in the water tank, or I just lost half of the water by these readings…
Is it because I am trying to do this on a Raspberry Pi Zero W - and its just underpowered to do any accurate clock measurements ? How can I improve my accuracy on this so I can get better consistency ?
