Uninterruptible Power Supply UPS HAT For Raspberry Pi Zero (WS-19739)
This is a placeholder topic for “Uninterruptible Power Supply UPS HAT For Raspberry Pi Zero” comments.
UPS module for Pi Zero delivers 5V output while charging batteries. I2C monitoring and auto battery switchover ensure continuous Pi Zero operation.
The lipo battery for this hat would seem to require a specific 40mm30mm8mm size lipo, but I couldn’t find the same size battery on your site. I have a number of sizes that don’t match this and would not fit in the space provided. Can you confirm if you have the right size/power specs?
Thanks in advance.
Hi again,
I suppose this is the correct battery: 1 X Polymer Lithium Ion Battery LiPo 1000mAh 3.7V 803040 30x40x8 Inc P – SM Components
Do you offer this exact size also?
Hi @Timothy56227,
While Core Electronics currently does not offer a LiPo Battery with those exact dimensions, I am glad you found a link to a supplier that is able to meet your needs.
Otherwise, all our LiPo batteries can be found on our [LiPo Battery Category page](Lithium Ion & Lithium Polymer Batteries Australia) here.
Hi Jane,
Thanks for your answer. I ordered those batteries, but then realized later they don’t come with plugs attached. I have used JST connectors before, but these look different. What are those little white plugs called that connect to the board, and do you sell those?
Hi @Timothy56227,
That should just be a 2-pin JST-PH connector.
We sell them here: JST-PH 2 Pin Female Connector | Buy in Australia | FIT0148 | DFRobot | Core Electronics.
You will need your own crimping tool to connect the wires. Probably the most affordable one in this case would be these crimping pliers for $31.05. The headers will just fit the smallest size of the pliers.
Thanks for the reply. I finally received the UPS HAT, and it actually comes with the battery, so I just misread the description, which has a list of “Technical Specifications” which to me meant that’s what it would work with, not exactly was included with the product!
Well, I’m glad for a happy ending at least. I might try and make the product description a little clearer for the future. Happy making :slight_smile:
Hi Team, does “Uninterruptible Power Supply UPS HAT For Raspberry Pi Zero”
(SKU: WS-19739) come with a battery included? Many thanks. My email is tom-bass@live.com.
Hi @Tom298245, welcome to the forum,
Yes it in fact does, as verified by @Timothy56227 earlier in this thread.
I’m going to go ahead and update the webpage for the UPS Hat to make that explicit.
