UPS for raspberry pi 4
Hi all, can someone please tell me if this battery is compatible with the Witty UPS for the raspberry pi 4?:
Battery:
https://core-electronics.com.au/polymer-lithium-ion-battery-2400mah.html
Polymer Lithium Ion Battery (LiPo) 3.7V 2400mAh
Witty:
https://core-electronics.com.au/witty-pi-4-l3v7-rtc-power-management-for-raspberry-pi.html
Also please let me know that battery would require any soldering or if I can just connect it to the Witty via cable.
Hey @Roman301249,
The Witty Pi 4 L3V7 connects to its backup battery via a 2-pin JST-PH (PH2.0) connector, as shown in the image below:
The battery you linked is a 3.7 V LiPo with a 2-pin JST-PH connector, so it should be physically compatible and can be plugged in directly, no soldering required.
As noted on the product page for the Witty be sure to watch out for battery polarity - connecting non-Adafruit batteries with the wrong polarity can instantly destroy your Witty Pi and possibly the Raspberry Pi beneath.
Great, thank you Ryan. I’ll make sure to check the polarity before connecting the Battery.
I remember something a few years ago where a particular battery manufacturer had the wire swapped on the JST. If you just plugged it in, +ve and -ve were the wrong way around.
Suggest using a multimeter to verify the actual voltage on the JST pins and compare with what is needed by the Witty.
Thanks James, I’ll do that
Yes, the battery is compatible—Witty Pi supports 3.7 V LiPo batteries, and your battery fits the connector type exactly. No soldering required. It’s a simple plug-in connection.
