Hi everyone,
I’m trying to connect 2 PiicoDev Laser Distance Sensor VL53L1X to a raspberry pi 4, as pictured in the image below.
I am using the following code to read from the sensors:
from PiicoDev_VL53L1X import PiicoDev_VL53L1X
from PiicoDev_Unified import sleep_ms
from time import sleep
from gpiozero import OutputDevice
# Change these pin numbers to the XSHUT pins you are using
shutdownA = OutputDevice(17)
shutdownB = OutputDevice(22)
# Shutdown all connected sensors
shutdownA.off()
shutdownB.off()
# Enable A for initialisation
shutdownA.on()
sensorA = PiicoDev_VL53L1X() # initialise sensor A with default address
sensorA.change_addr(0x2B)
# sensorA now has a new address
# Enable B for initialisation
shutdownB.on())
sensorB = PiicoDev_VL53L1X() # initialise sensor B with default address
# There are now two sensors initialised with separate addresses
# sensorA is at 0x2B
# sensorB is at 0x29 (default)
while True:
distA = sensorA.read()
distB = sensorB.read()
print(f"{distA:4.0f}A, {distB:4.0f}B") # print both distances on same line
sleep(0.1)
However, when I run the code I get the error:
File "/home/drone/Desktop/test/test.py", line 47, in <module>
sensorB = PiicoDev_VL53L1X() # Initialize sensor B with default address
File "/home/drone/.local/lib/python3.9/site-packages/PiicoDev_VL53L1X.py", line 111, in __init__
self.reset()
File "/home/drone/.local/lib/python3.9/site-packages/PiicoDev_VL53L1X.py", line 135, in reset
self.writeReg(0x0000, 0x00)
File "/home/drone/.local/lib/python3.9/site-packages/PiicoDev_VL53L1X.py", line 124, in writeReg
return self.i2c.writeto_mem(self.addr, reg, bytes([value]), addrsize=16)
File "/home/drone/.local/lib/python3.9/site-packages/PiicoDev_Unified.py", line 119, in writeto_mem
self.smbus_i2c_write(addr, memaddr, buf, len(buf), addrsize=addrsize)
File "/home/drone/.local/lib/python3.9/site-packages/PiicoDev_Unified.py", line 132, in smbus_i2c_write
self.i2c.i2c_rdwr(msg_w)
File "/home/drone/.local/lib/python3.9/site-packages/smbus2/smbus2.py", line 658, in i2c_rdwr
ioctl(self.fd, I2C_RDWR, ioctl_data)
OSError: [Errno 121] Remote I/O error
When I’m running only 1 sensor, I can change the address and initialize the sensor. But the moment I try to initialize the second sensor I run into this error.
Any help or advice would be greatly appreciated.
