W11 Modbus program
Hi all.
I’ve got a new-ish Sofar Inverter that has an unused RS485 connection. I’d like to get Modbus data from the inverter into HA but before I do that project I’d like to confirm that the inverter will spit out the Modbus data. The manual is very vague about this.
I’ll get a USB to RS485 dongle but I’m after recommendation of some Modbus freeware I can run on a laptop to prove the data is available.
Recommendations anyone?
Mark
Hi Mark, I use modbustools.com It is a 30 day trail that should get enough testing done in that time. I used it for my sungrow inverter for the same reason you want to do.
Thanks Matt
In the end I didn’t need to physically connect to the inverter and use Modbus. Turns out its wi-fi dongle is actually a data logger so having got the manual and the registers, it was pretty straight forward to get the data.
