The ESP32 unit I’m using says WROOM 32 on it; I have “ESP32-WROOM-DA Module” selected in the Arduino IDE. I have a string of 200 RGBA LEDs wrapped around a tube, so that I have two rows of 100 LEDs, which I’ve split into two groups (I’m sure there’s a much easier way to declare those arrays, but I seem to be a dunce when it comes to learning how to code). Anyway, I doubt that’s causing my problems here. First problem is that my A/Ds are giving me nothing half the time, even when I’m feeding them a constant sine wave at 440Hz. My code includes some lines to print millis and the raw values coming from the A/Ds, and this is what it looks like:
6912 0 0
6918 243 202
6924 396 411
6931 43 145
6937 0 0
6944 0 0
6950 0 0
6956 376 336
6963 271 351
6969 0 0
6976 0 0
6982 0 0
6989 201 112
6995 396 407
7001 110 203
7008 0 0
7014 0 0
7021 0 0
7027 356 304
7033 325 380
7040 0 0
7046 0 0
The second problem is really baking my noodle too, but I have a feeling someone might just tell me I’m using the wrong pins or something; when it gets a signal in the left channel it sees a signal in both channels; when it gets a signal in the right channel it sees a signal in the right channel; when it gets a signal in both channels it only sees a signal in the left channel! Aargh! Doing my head in.
Here’s my pathetic code:
#include <FastLED.h>
#define NUM_LEDS 200
#define DATA_PIN 15
CRGB leds[NUM_LEDS];
byte grp0[] = {0,2,4,6,8,10,12,14,16,18,20,22,24,26,28,30,32,34,36,38,40,42,44,46,48,50,52,54,56,58,60,62,64,66,68,70,72,74,76,78,80,82,84,86,88,90,92,94,96,98,100,102,104,106,108,110,112,114,116,118,120,122,124,126,128,130,132,134,136,138,140,142,144,146,148,150,152,154,156,158,160,162,164,166,168,170,172,174,176,178,180,182,184,186,188,190,192,194,196,198};
byte grp1[] = {1,3,5,7,9,11,13,15,17,19,21,23,25,27,29,31,33,35,37,39,41,43,45,47,49,51,53,55,57,59,61,63,65,67,69,71,73,75,77,79,81,83,85,87,89,91,93,95,97,99,101,103,105,107,109,111,113,115,117,119,121,123,125,127,129,131,133,135,137,139,141,143,145,147,149,151,153,155,157,159,161,163,165,167,169,171,173,175,177,179,181,183,185,187,189,191,193,195,197,199};
void setup() {
Serial.begin(115200);
FastLED.addLeds<WS2812,DATA_PIN,BGR>(leds,NUM_LEDS);
FastLED.setBrightness(127);
void loop() {
int LInLev = analogRead(25);
int RInLev = analogRead(26);
int sens = 99; // min 99
int LLev = map(LInLev, 0, 1023, 0, sens);
int RLev = map(RInLev, 0, 1023, 0, sens);
fill_solid(leds, NUM_LEDS, CRGB::Black);
for (int iL = 0; iL < LLev; iL++) {
leds[grp0[iL]] = CRGB::Red;
for (int iR = 0; iR < RLev; iR++) {
leds[grp1[iR]] = CRGB::Green;
FastLED.show();
int tme = millis();
Serial.print(tme);
Serial.print("\t");
Serial.print(LInLev);
Serial.print("\t");
Serial.println(RInLev);
The poxy red and green is just for testing; I’m planning on something a bit fancier than that, but the damn thing has to work first. If anyone can tell me where I’m going wrong, that would be greatly appreciated ![]()
