I have 2 wireless ‘key‘ gate keypads mounted to a 50mm rhs steel post. They control an electric driveway gate. There is no 240v power at the keypads. They are powered by a 3 volt battery pack (2 x AAA alkaline batteries in series) with a 2 pin jst connector. They last around 12 months.
Okay, what’s the voltage and capacity of the particular battery that you’re using. If it’s 3x AAA I’d say it’d be pretty close to 3.6V or 3.7V ~3000 mAh. If so, then any battery with more capacity than 3000 mAh and 3.7 V should be suitable for this one. (Such as that I’ve linked below)
If there’s anything else that I can help you with please let me know!
Okay, depending on the clearance you’ve got, you may be able to fit one of these appropriate holders into the device. Otherwise, I’d check the min and max voltage ratings on your part, as you may be able to get away with running this at 3.7 V from the battery above.
Bryce
Core Electronics | Support
