Polymer Lithium Ion Battery - 3.7V 2400mAh (CE04379)
This is a placeholder topic for “Polymer Lithium Ion Battery - 3.7V 2400mAh” comments.
Welcome to the awesomeness that is LiPo batteries. Polymer Lithium Ion batteries offer superior energy density with this 2400mAh battery being on 6mm in height!
What’s the connector on this battery? Is it JST? Which series?
Hey David, the connector on all of our Polymer Lithium batteries is a standard 2-Pin JST-PH (2.54mm) Connector.
2 posts were split to a new topic: Replace the LiPo battery in my dash-cam
3 posts were merged into an existing topic: Replace the LiPo battery in my dash-cam
Is this suitable for the MKR 1500 NB? Does it have a female 2 pin JST PHR2 Type connector?
Hey Andrew,
Welcome back to the forum!
The JST connector on the MKR 1500 NB is compatible with our 2-pin 3.7V LiPo batteries. JST-PH connectors are designed to “lock in” to the appropriate sockets to maintain proper continuity, so just a word of warning you may find the connection to be a little snug if you try to remove it from the socket after plugging it in.
