Hey there!
TLDR: Is it possible to connect the WS-24155 to the SS113991114 with Micropython?
I’m trying to build a small project with Wi-Fi and a touch display, preferably in MicroPython.
I’ve looked through the pin connections and demo code for the WS-24155, and found that to connect to a RPi Pico (proggrammable with MicroPython), it requires 1 SPI interface (2 pins), 1 I2C interface (2 pins, it doesn’t seem to use the miso pin), 5 regular pins and 1 PWM (provided by GPIO).
I am aware that the ESP32 can be programmed with MicroPython, but has different names for the pins, but the machine library is on all Micropython devices, so would I be able to connect the SS113991114 to the WS-24155 using something like this:
I would also slightly modify the Pico demo code with the correct pin numbers.
Thanks!
