ESP32-S3 Development Board, with 1.28inch Round Touch LCD, Accelerometer And Gyroscope Sensor, Round Display, With CNC Metal Case (WS-26959)
This is a placeholder topic for “ESP32-S3 Development Board, with 1.28inch Round Touch LCD, Accelerometer And Gyroscope Sensor, Round Display, With CNC Metal Case” comments.
ESP32-S3 Development Board, with 1.28inch Round Touch LCD, Compact size, Accelerometer And Gyroscope Sensor, Round Display, With CNC Metal Case…
Is the connector on this the same as the JST GH 2P (1.25mm pitch)?
I’m uable to determine what connector is the MX1.25
Hi Richard,
Welcome to the forum!
I think this Molex Picoblade connector should work: Molex Pico Blade 2-pin Cable - 200mm | Buy in Australia | ADA3922 | Adafruit | Core Electronics
My thought process for picking that one comes from this product: SX1262 LoRa Node Module for Raspberry Pi Pico, LoRaWAN | Buy in Australia | WS-21667 | Waveshare | Core Electronics
It features a similar-looking connector.
Unfortunately there isn’t one in stock Core can test. I couldn’t track down a GH-2p that Core stocks.
Can you fit a LiPo battery inside the ESP32-S3 Development Board and 1.28inch Round Touch LCD With CNC Metal Case? If so, which one please?
Hey @Alex308189 , welcome to the forums!
I opened one of these up and checked the dimensions, and the short answer is no. You won’t be able to fit a battery inside of this case. There is a small amount of extra space inside, so something like this 120mAh LiPo will physically fit, but not with enough clearance for me to be sure you wouldn’t have any heat issues or problems with battery expansion later down the line.
If you want to use this with a battery, I would suggest making or 3D printing a larger case or storing the battery externally.
Hi Alex, there’s a project on hackerster.io where the author 3D printed a different back cover to accomodate a LIPO battery:
